Updated to 2.1.04 and lost the camera calibration
Updated to 2.1.04 and lost the camera calibration.
Is it stored somewhere from previous version
It is usually stored by default with your device settings, and there is a way to restore previous settings:
You can try the above, however, if the settings did not automatically carry to the new version (what version were you previously using?) then I would recommended that you calibrate the lens and alignment again following this new guide:
Thanks for the reply.
I will do a fresh calibration.
Does the .lbcm file contain both lens calibration and alignment data or only lens calibration?
Alignment data is also stored in the .lbcm file - as long as it was saved when a valid alignment was present.
Thanks for your response.
