I don’t want to be so scared with this construction, just the bolts are tight well. Maybe I would go up a step with bolt dimension….
If the base plate is very thin and flexible, I will make 2 aluminum plates as reinforcement but then you also need to make a new bridge.
But as I said, since there are no moving parts, I will not change too much.
