We’re looking to hire someone experienced with MOPA fiber lasers and LightBurn for hands-on setup and training at our home in suburban Denver. This is urgent—we’d like to arrange a session as soon as possible.
Our setup is a ComMarker B6 60W MOPA running LightBurn on a Mac. We’re moving from an X1 and its integrated software. We’re technically comfortable, but getting consistent results with this setup has been a tougher transition than expected.
The machine is running and engraving. We’d like someone to help us:
Verify our configuration, focus, and calibration.
Dial in clean powder-coating removal on stainless steel tumblers.
Understand how speed, power, frequency, pulse width, and line interval work together.
Build a few tested presets and a repeatable process for dialing in new materials.
Our goal is to understand the process and confidently reproduce good results ourselves.
In-person help is strongly preferred, ideally for an initial few-hour session. We’re open to paid live video training if we can’t find someone local with the right experience.
Have you hit a snag learning from the myriad of LightBurn resources available? We’re very happy to help if we can - but won’t judge if you prefer to have a more 1-on-1 option, which we don’t offer.
I have a 50W co2 I use for mugs and I use it over the fiber for a simple reason, the co2 cannot damage the metal, so it’s a safer option rather than a fiber. However, both will work.
One of the biggest differences is you’re used to a continuous wave (cw) co2 machine. As the wavelength gets longer the metals absorb less and less energy. If you use too much power it’s quite easy to discolor or warp the metal.
Another issue with metals are their heat conduction. Some metals, like copper, really sucks the heat out of the lasers work area. This happens with all metals.
What makes a fiber work is it’s pulse machine. As such, it peak power can be in the kw. My 60W has a pulse peak of 18kw. So if the material only adsorbs 10%, it’s still 1.8kw.
Since you have a MOPA it’s advantage is ability to adjust both pulses/s and width of the pulse (q-pulse).
If you change mug type or batches, it may not work that great, since material have minor changes as does the coatings. How do you propose to ‘dial it in’ if you don’t know what the settings accomplish.
Everybody here is on your side and we will all help you as much as possible to get the desired results. Usually posting a photo and/screenshot of the settings will help stir people up to get you help.
I doubt a few hours are going to help that much. I’d suggest some of the videos from Laser Everything, they will help you a lot. On their youtube channel they have how to focus, how to setup delays and one of their best is on photo engraving. I know that’s not what you’re doing but it covers the proper selection of the interval is very important to your results.
Sing out if you have specific issue and we’ll help you answer them.
