Using a Roundover bit
I would like to use a roundover bit but do not see an operation for this bit. What Operation should I use and what settings? Thanks.
Here is a link to a roundover set I purchased.
I am trying to round the edge of a pocket.
Although I can’t help you also new at mileage! I’m keen to see if or when you get a response we’re growing together mm and I !…..be after they get back now I presume
Pat
I do not think they have a tool procedure for that yet, but maybe you could do something like a single pass around the pocket rim (outline) at a fixed depth. Just thinking out loud here.
Thanks Mike. I have been trying that but it’s a bumpy road.
Maybe draw it as a cross section at 1:1 scale in MillMage. Then you can check position and measurements pretty accurately.
You could try a profile pass along the path up to the radius’ depth after the pocket is cut out?
With a part, you might get only one “try”, turning it into scrap. If I do not know for sure the outcome, I will sketch, to scale if necessary, what is supposed to happen and see if the numbers compute. Paper is way cheaper than materials. Even if I get it wrong, I can usually spot where I screwed up and call that experience.
Experience is what you get when you don’t get what you want. :joy:
True, but there’s not only one way to generate the right toolpath.
It’s why we have the preview built in :grin:
have a read of this post , will help with some of the mistakes i made when 1st doing round overs
