I am trying to utilize LB with my Laser Pecker 4 and rotary attachment in the vertical position to embellish my turned wood cremation urns “in the round”. I have downloaded lbdev file for rotarys. My problem is, in Rotary setup, the rotary turns if I hit the Mirror Output to Rotary in Laser Tools window, but will only burn in a single linear fashion - just in one line. But if I dont use the Mirror Output to Rotary button the rotary will not turn. And the laser will Frame and burn in a stationary window. Can you help?
Hi Dave and welcome.
Did you input M3032 ? Following the doc:
https://support.laserpecker.net/hc/en-us/articles/7638927193231-Operating-LP4-with-LightBurn
And did you check the LightBurn doc:
