Using ver 24
Tried the reduce speed by 10% (was running at 1200 mm/min)
couple seconds later machine slowed down
BUT had also shifted to the left about 40 mm
Eleksmaker GRBL with 32 bit nano Mana se control board 2209 stepper drivers 0.9 steppers
AND each time I clicked reduce by 10% it kept shifting to left approx 40 mm
It then was off the 100mm tile I was etching
This obviously doesn’t help your issue, but just reporting that this doesn’t happen on my Ortur LM2
I uninstalled --and re-installed now its working Thanks
