Ustawienie punktu poczatkowego głowicy lasera (Setting the origin of the laser head)
witam wszystkich
Posiadam zmodyfikowany Neje 3 z głowica lasera SCULPFUN S9 i porzeszonym obszarem roboczym.
Mój problem polega na tym że gdy chcę coś wyciąć głowica nie zaczyna od górnego prawego rogu pola roboczego tylko około 40 mm poniżej, próbowałem zmienić punkt poczatkowy ale mi sie nie udaje może robie to n ie tak, proszę o porade gdzie moge ustawić właściwy punkt poczatkowy
hello everyone
I have a modified Neje 3 with a SCULPFUN S9 laser head and a large working area.
My problem is that when I want to cut something, the head does not start from the upper right corner of the working field, only about 40 mm below, I tried to change the starting point but I can’t, maybe I’m doing it wrong, please advise where I can set the correct starting point
Poste doch mal einen Screenshot von deinen Einstellungen. Sowohl von LightBurn als auch aus der Firmware. Dann können wir weiterschauen.
Post a screenshot of your settings. Both from LightBurn and from the firmware. Then we can look further.
Uploading: lightBurn.png…
Uploading: lightBurn.png(1)…
Unfortunately, I was able to post only two screenshots, I got a message that new ones are limited to two photos
I’m new to the forum and I can’t attach photos, please help me, thank you in advance
Did not work. There are no pictures…
Uploading: lightBurn4.png…
You need to wait for the picture to upload before you hit send.
hello again and I am asking for help, I think I managed to post pictures of the settings, are they visible?
The last two pictures are visible. Next time, change the LightBurn language to English, this also helps in understanding. What I can see is that you set the origin of the laser to top-right, which is wrong. The origin is always bottom-left. Check devices settings as well for this setting. And you are using an older version of LightBurn, it might be worth to update.
hello, thank you for your help, I set it as you suggested to the lower left corner but nothing changed working area at 200x206 mm, the frame command performs 200x206 and reaches my starting point from which to start work, but when it comes to engraving, the point moves as if by 30 mm, i.e. to the area of ​​170x170 mm, am I right and can it be changed in any way ?
I see that you are auto-homing on start up.
Are you attempting to change the origin or just the point you start your job from?
Have you moved the limit switches to the top-right?
With your engraver connected, please request the following reports from the Console Window in LightBurn:
$i
Pressing enter after each one.
Please copy and paste those responses into a reply here. Some of the information required to answer your question is missing from pictures. A copy of plain text will be easier and more compassionate to work with.
first of all I would like to change the starting point of the engraving/work
Please respond with the requested reports.
I’ll need that swath of information before anything else.
Uploading: console.png…
