while running a v carve i tried to increase feed speed went right up to 200 % didnt seem to change at all ?
question is it meant to increase like it dose normally, in say a profile cut when using core 8
or is this something that is off when in V carve
It has nothing to do with the operation type - the code that increases the feedrate doesn’t know what type of operation is running - it’s a global change.
What’s more likely is that your machine has a relatively limited Z axis speed - since the V carving tool path moves the Z axis a lot, that will tend to be the limiting factor.
