V1.4 2nd window will not connect to laser
I’m using V1.4 of lightburn. When I open a 2nd window to work on a project it will not connect to the laser Even when the job on the window is finished. I use win computer. I tried to connect the laser but it won’t connect. Is 2nd window only for working on projects and not to do the work. I’m using one laser on this computer right now.
You’re not meant to connect 2 instances to one laser. One instance per laser or instances with no laser.
thanks that is what I needed to know
