Hi, I have created a variable text serial number array commencing at 1 and finishing at 30. Appears to work fine in preview, but when the file is saved then re-opened, it reverts the first digit to 0, so does not appear to retrieve the CURRENT value from the file. I can always work around this by setting the current value back to 1 in the variable text window. On re-opening the file the variable text values change to: current = 0, start = 0, end = 4 which are obviously not what were set when i created the file.
cheers
Robert
