I’m experimenting with variable text. When using Cut settings “d 0r D” expression it always returns 254 regardless of the actual layer setting. The interval displays correctly. Using 1.7.04
Hi Tim, I think something broke during one of the last updates.
Here is my result from a standard variable text message I like to use on my projects.
I think it’s related to to a known problem, which was otherwise solved.
