Can LightBurn be set to count backward when engraving Serial numbers in variable test? We have to load parts, so the highest number is on the bottom of the pallet. So… we start with the highest number and work backwards so the lowest number is at the top. This allows the customer to pull parts with increasing serial numbers. Thanks
I don’t believe there’s a way to do that today with serial numbers.
As a workaround, consider populating a CSV file with decrementing numbers per row and using “Merge/CSV”. This should get you the same basic effect assuming you have no other constraints that haven’t been mentioned.
I had to look that up, as I didn’t realize Lightburn could do this. Very useful.
