If I create a design in 0.9.16 and send it to the laser it follows the paths OK but won’t fire the laser,
If I open the design in any previous version it will cut & engrave as expected.
Controller : Trocen-AWC
TIA
Fred
TIA
Fred
I’ve had an issue in certain instances where if the output is on layer 00 (black), my laser won’t fire but if I change to any other it will. Not had a chance to mess around with the layer settings to see if something is amiss but try changing layers and see if the laser fires for you.
Can you attach the file here, or send it to support at lightburnsoftware? There’s a decent chance that some new setting is enabled that doesn’t exist in prior versions.
