Version 2.2 cannot import SVG files from Coreldraw
When i try to import svg files from coreldraw it says nothing imported, none of the previous versions have done this, i rolled back to 2.1.04 and the files import as usual.
I use CorelDraw 2024, and I just tested it using the attached SVG, and it worked fine. I am exporting SVG using these settings.
its also not all svg’s some of the simpler designs will import but others won’t. it wont let me upload the file here for some reason it comes up with an error could not determine the size of the image
Hey Mark,
If willing, you could host with a file sharing service (Google Drive, OneDrive, fileio, or similar), make it public, and share the link here. :slight_smile:
Thank you, https://drive.google.com/file/d/15aA1xZ6qnGXWc0ur6PPmiQqZvqBwfDEX/view?usp=sharing
linked above, file will open in 2.1.04 but wont open in 2.2
I can verify that the SVG file also opens in LB 1.7.06
I can open the SVG in CorelDraw 2024, and export a new SVG, and LB 2.2.00 opens it.
ive had chat gpt scan the non working file and the working file and it found this. something to do with the coordinates but version 2.1.04 had no issues with the coordinates and if i drop the scaling precision down to 1;1 in coreldraws svg export settings the file works in 2.2 however the artwork is messed up and severely distorted text.
However, there is one significant difference:
Original (-2) Fixed
ViewBox width 2,216,332 22,163
ViewBox height 2,355,988 23,560
Physical width 69.9452 mm 69.9452 mm
The original uses coordinates approximately 100 times larger than the fixed version.
My theory
I suspect LightBurn 2.2 has a problem interpreting the unusually large coordinate values in the original file.
