Version 2 fails to import high-resolution-photos
I’m using Windows 11. I’m unable to import high-resolution-photos in version 2. The same photos import perfectly fine in version 1.7. Has anyone else experienced this issue?
Hello Dominique.
Could you write us to support@lightburnsoftware.com and provide a sample image that is failing to import on 2.0 bu works on 1.7?
Thanks!
Hello Dominique.
Issue was found and corrected by Dev team for the next build.
Thank you for reporting
