I would think is has something to do when you cleaned your lens. Is the lens a screw on, or does it come apart. I don’t know if they can be put in backwards as mine just screws off and back on. Also check and see if it’s cracked.
To @ednisley how do I know without a shadow of a doubt? In truth it was working. I tipped the laser over to start cleaning the ground. I’m considering just purchasing a 10W. At this point. I do a ton of laser plates. Maybe it’s better suited for my needs anyway, but still I’ve had the laser for less than a year .
Remove the outer lens / protective cover, inspect it, then inspect the lens (or whatever) inside the laser head. A magnifying glass and strong lighting will be helpful. If any of the optical components are anything other than perfectly clear, that’s the source of the problem.
Uploading clear photographs will let the hive mind look over your shoulder to spot things you may miss.
Photos of a wall test will also help verify the optical path.
