Can Light burn be used on this machine
WAINLUX Laser Master 2 Laser Engraving Cutting Machine With 32-Bit Motherboard 20w Laser Printer CNC Router
Thanks All
Thanks All
If you mean this unit: https://www.aliexpress.com/item/1005001721719737.html
… probably not. I can’t see anything that suggests it uses standard firmware, and it has a mobile app, which means it’s almost certainly proprietary.
I’ve got someone else that emailed us, they tried to connect to it over USB - it does show up as COM port (apparently), but that’s about it. Strong possibility of custom firmware, so no go.
Thank you
