Warp / deform tool
So, i recently discovered the warp/deform tool which works perfect for a lot of curved wine glasses I use. A little clarification of how I work:
I receive a file from a buyer that they want engraved, this image is always the same dimensions. The problem is, I have to deform every image/text again and again.
Is there any way I can ‘save’ a deform or make it default or a template? Like I said, the files I work with always have the same sizes, so I always have to do the same deform over and over.
Hope there might be a clever solution for this, thanx in advance :slight_smile:
Maybe a better way but I think I would set up some squares/rect. etc. to use as guides to quickly align to and save that. And you should be able to lock them so they don’t move.
