Hello,
I’m having an issue and I’m really scratching my head. I bought a grid file off etsy to engrave my wasteboard. I ensured I homed the LM2 before burning this grid. Grid burned fine, looks great.
However, If i delete the entire grid and add a 20x20mm square to where one was on the grid, the burn is off on the Y axis. It’s almost as if the entire grid is offset from what the laser will actually burn. If I manually set the origin to the lowest corner of the grid, I can get the laser to frame a square of the grid correctly. I homed the LM2 prior to burning the grid… and again before burning my 20x20 square, but it’s not correct. BTW-- both the grid file and the 20x20 square are being burned using coordinates…
Uploading: IMG_8864.jpeg…
I want to figure out why this issue is occuring, so that I can setup my rigs true to the wasteboard and burn some stuff… I’ve tried everything I can think to do and researched the issue but I’m not getting anywhere. It doesn’t seem to be a hardware issue (belts are tensioned, burn quality is high, but off) more of a disparity in origins or something but I’m not an expert… Hence why I need help. Thanks everyone!
