Wavelines on a few images
Hello, when recording images I get some ripples in some parts of the image, and when making lines or cutting, some vertical lines move a bit, I have removed the bi-directional scanning so that it only makes one line in each pass…
It is likely a hardware problem. Either the timing belt is too loose or too tight or the pinion screws in the pulley are loose.
I use a falcon on an ender 3 pro (3d printer) and when I put it to 3d print it works perfectly, so I think the straps and so on are correctly tightened…
[quote=“ebsigma, post:3, topic:130912”]
[/quoteIt is well possible, but the symptoms are very similar to what I wrote about. You could try to reduce your speed and do some tests.
ok, next time i will reduce speed and tryit again thz
Remember that 3D printing speeds are typically much slower than laser cutting speeds, so the mechanics behave differently.
