Weld and booleon not working
it doesnt matter what i try I can draw a circle and then a square and the weld command may or may not highlight… booleon never does. it just started in current version
Post your project for us to check.
2 conditions need to be met for the Boolean tools to appear:
  1. You are working with closed shapes only
  2. You have selected 2 and only 2 shapes. Note that Grouped shapes count as a single shape in this case so 2 grouped shapes would also apply
Have you met these conditions?
broken file. though the center was a closed circle the file was corrupt and causing closed circle to show open. reloaded original file from a few years ago and it fixed it. thank you for the direction
