I am trying to weld two shapes, one comes from other project and the second one is a circule that I am trying to weld with the first one, I select the circule then shift and select the other shape click weld and nothing happens, please provide me with clue. Thank you
Ich habe Dir hier nur den Vogel mit der Funktion “auto join selected shapes” geschlossen.
Dazu musst Du erst die Gruppierung aufheben.
Das “welding” überlasse ich Dir, weil ich nicht genau weiß, wo Du das Ei haben willst
I’ve only closed the bird for you here using the “auto join selected shapes” function.
To do this, you first have to ungroup it.
I’ll leave the welding up to you, because I don’t know exactly where you want the egg.
Thank you! I will try to replicate your solution I cannot download you are using version 2 I am usin 1.7.08 anyway very much appreciate your help, have a good day
