I’m working on a mac running venturi on a chinese diode (LDHTHOPI)
Are you referring to GRBL $ configuration values?
If so, here’s a reference:
grbl/settings.md at master · gnea/grbl · GitHub
Aaaaand, of course, everybody who writes GRBL-based firmware (*) adds unique parameters with no documentation anywhere (that I’ve seen): when the parameter you seek isn’t in that list, it’s not GRBL’s fault.
(*) Which, depending on the circumstances, can be pronounced “rips off GRBL firmware without paying attention to the GPL”.
Another very good reference can be found here:
http://linuxcnc.org/docs/html/
Although it is oriented towards LinuxCNC implementation, there is a very good section on G-Code, and it provides detail that many of the other G-Code references ignore or gloss over.
