IN/MM digital calipers, 18" IN/MM ruler, bin with the magnetic material hold-downs, laser-safe glasses (in case), water sprayer, pencils, toolkit… Anything else?
A box of cotton-buds (Q-tips) are handy for when you venture to clean around the working end of the module, and then advance on to clean the internals like cooling fins and fan. I did the easy external stuff first, then the fan and fins, and then both end caps off for a thorough internal clean right through…but I stayed away from the driver board as yet which should maybe only get a dust off with canned air.
Everywhere gets a clean with Isopropyl on the Q-tip and I generally use about 8-10 per clean. Heavy gunk with one end and polish off with the other. They are really great to push through the cooling fins and be real gentle with the fan.
This will keep the internal temperatures down and prolong use.
What are your boxes cut from?
Plain old corrugated cardboard, free with (nearly) every Amazon delivery and I’m still working through a pile of moving boxes.
The pens in the middle fit into an early version of a holder for a laser power meter, so that’s plywood.
A diode laser will probably have trouble punching through the internal corrugation layer, so chipboard or MDF might work better.
And one last thing, a Crying Towel.
CO2 fire extinguisher
