What happened to the pulse setting?
I put in the 210 mm lens and now when I manually input material settings, there is no pulse control.
When I was using the 160mm lens it was always there?
How do I get it back?
Hello, @claudia2004
Try here first if I understand your question.
Other possibility is beginner mode
It’s usually smart on these to duplicate your working lens device to another name and go through the lens setup. I’m assuming this is a new lens?
Thank you! That was easy
Thank you!
