When using the Print and Cut function, is there a recommended way to position the two alignment targets to get the best registration?
For example I assume that the further apart the two target are, the better, but does it matter if they are both on the same Y position line (one on the left and one on the right edges of the material) or does having the targets offset on the Y axis help. Or does it not matter at all how the targets are positioned.
Having them both on the same Y axis makes setting the laser easier since I can just position on the first one then just jog the laser head straight across the material and set the correct X position for the second target.
