What is the cause of windows not docking?
I’ve asked this question before and it seems to be overlooked.
The area will not turn blue as described in the tutorials
What is it that I’m doing wrong.
The window needs room to dock. The main window needs to be tall enough to accommodate the window being docked into the place you’re trying to dock it. If the main window height is too short to fit the window, it won’t allow it. You can shorten the cuts list by dragging up the bottom, and try again. If that doesn’t work, it might be that the overall display height is too short and you have to stack them on top of each other, instead vertically stacked.
See here:
Good information.
Thank you.
I’ll play around with it.
