what is the settings in lightburn to be able to cut the right size.when i try to cut 100mm it cuts 50mm, i am useing a grbl mostic pro 3018 diode laser and paid lightburn software.
is there a way in lightburn to make it cut the right size, or in grbl settings.
Generally if this has worked before, it should work with lightburn.
Ensure you have gone through these
https://lightburnsoftware.github.io/NewDocs/CommonGrblSetups.html
https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
Ensure that your machine and all software is set to the correct units.
Sounds like you need to calibrate your x and y axis.
