I have a picture that I wanted to do an offset trace to cut out. Unfortunately, I was unable to figure out if LB was able to do this.
I imported a bitmap and did a trace image. I then applied scan mode. When I tried to do an offset, it would offset both inside and outside of the object. I would like to only offset the perimeter to cut out the entire object. Is this possible?
If you trace an image, you’ll get the entire thing traced, and if the result is multiple shapes, they’re grouped. Un-group the result, delete the stuff you don’t want, then offset the remaining curve.
I have a longer term plan to add a mechanism for selecting which outlines to keep from within the capture dialog, and having a “clip rectangle” for use with the bed capture, but it’ll take a bit to add that.
