When I bring up cuts and layers all I get is fill offset fill and line but no cut. Thanks Ray
You need to set a line for cut. Speed and power and passes.
The only difference between a line and a cut is the power and speed… Most engraving is removing material, engrave deep enough and it’s cut…
I get a image I want to line in lightburn on my xtool d1 pro 10 w. The display says ready on com port 3, but when I try to start machine it says the d1 is busy or paused. Thanks Ray
This is a different subject. Will you please start a new topic?
That way others who might be able to help won’t miss the opportunity.
Thanks
I tried to set up my xtool d1 10w laser. When I go into lightburn it asks me to set up laser, but it does not recognize it as no serial ports show up. Thanks Ray
I am having this same problem I set a line to cut and choose power and passes still dont have cut or scan & cut. Is there a software problem because I can’t get it to cut
