I am running with MKS Sbase(GRBL-LPC) controller, speed 15mm/sec. the lightburn did not finish the job and stop on a point with error code 25. what might cause this happen? since the Gcode were produced by lightburn.
I did this 3 times, and the results were same.
Those shapes were made by illustrator and were success cutting when I use my other control board, which is M2 nano on K40 whisperer.
Hopefully some can help me out.
I changed the usb port, problem gone.
Super news, can you please go into the message reply section and select Solved so people searching with a similar issue can quickly find things that have worked
Thanks
Gary
