When selecting image items in LB items auto delete / dissappear
When creating sketches in LB after approx 30+ minutes (active use) the selector pointer starts to remove / delete(?) selected items which are then irretrievable thus destroying previous build.
Has any one experienced this.
fyi I always accept new version prompts when signing into LB.
regards
Phil
2 things, doesn’t undo restore the missing items?
Change the batteries in your wireless mouse. Worth a try.
Hey Tim,
thanks for the prompt response!
Selecting Undo / Restore ‘flashes’ the image momentarily but it still appears to be lost.
Initially thought that the item was made invisible (but still there) but it cannot be detected afterwards.
I replaced mouse batteries and problem still present.
Thanks again
Phil
One more thing to check. Do you have “show” enabled on all layers. Possibly you inadvertently changed layers.
Tim,
Layers all visible and up to time of ‘glitch’ everything is working fine with no hint of issue.
Appreciate your input!
Up to now I’ve just stopped working on it and shut the program and pc down and return next day. (Good job this is a hobby!).
This removes the issue for the next work session but on for 30-40 mins.
Thanks
Phil
CTRL-Z rolls back through your changes.
SHIFT-CTRL-Z will roll them back forward (undo the undo).
The fact that a reboot seems to temporarily clear it up, I am suspecting it is an operating system issue.
Thanks MikeyH,
Since I’m using Windows 11 I’m hoping that I wouldn’t be the only one reporting this?
Phil
