Lavoiern
(Phil)
August 7, 2026, 10:28pm
1
The message is it detects wecreate but not using gcode device with wecreate device flavor. The camera responds to focus and a picture of the bed is there. It frames and calibrates but stops when a-lining. The camera moves then stops
Lavoiern
(Phil)
August 7, 2026, 10:40pm
2
This is the message I get
soniclab
(Jeremy Hutchinson)
August 7, 2026, 11:12pm
3
You will need to select the GCode flavor during the New Device Setup
Go to Devices–> Create Manually, Select Custom GCode from the device list. Run through the device wizard and select the WeCreat flavor from the list.
Lavoiern
(Phil)
August 7, 2026, 11:48pm
4
I don’t have wecreate in that section I will try just GRBL.
MikeyH
(Mike Hembrey)
August 7, 2026, 11:59pm
5
Me neither. You may have to import the .lbdev file from the manufacturer (or maybe the Lightburn version) to see it show up.
soniclab
(Jeremy Hutchinson)
August 8, 2026, 5:56am
6
What version of LB are you using ?
Pretty sure you’re going to need the Custom GCode option and not the bog standard GRBL profile according to the console message.
soniclab
(Jeremy Hutchinson)
August 8, 2026, 5:59am
7
That’s probably the best course of action if you’re using an older version of LightBurn.
It’s kinda hit and miss with the WeCreat at the moment.
Aaron.F
(Aaron)
August 10, 2026, 12:54pm
8
The WeCreats work well if you’re using > 2.1.03 and the recommended settings.
You can download and import the settings file I posted here:
In Version 2.1, we added a dedicated WeCreat Flavor, which fixed known firmware compatibility issues.
Download the latest version again from here . You can install it over the old version without needing to uninstall first.
Then, download this device profile, and drag it to the workarea to add the device:
WeCreat_Vision_40W_08_2026.lbzip (30.6 KB)
Or this one for the Pro
WeCreat_Vision_Pro_08_2026.lbzip (25.2 KB)
Please let us know how it goes.
