When using array tool for multiple objects, the drawing lines misalign with the cut lines when cutting many objects
I have tried many times to use the array tool to make multiples of a given object like Christmas Ornaments. If there are too many vectors, it seems to misalign the engraved lines with the cutout lines. The items will get more and more out of alignment at the higher Y areas, and only out of alignment in the Y axis. I have tested the machine and it it in alignment, and is capable of repeating cut actions perfectly.
I have noticed if I select only some of the Ornaments at one time to cut it works fine. Then I select the next group, until done. What is the maximum number of items, or vectors that can be in one batch to prevent this problem? Has anyone else had this problem?
