When using lightburn software to carve patterns, err20 pops up, please ask what is the reason?
emphasized text
Maybe this helps
No explanation for ERR22
See here:
Error 22 : Undefined feed rate (Feed rate has not yet been set or is undefined)
It will happen if you send a G1 command and omit the required feed rate. For example:
G1 X30 Y30
instead of
G1 X30 Y30 F2000
or
F2000
G1 X30 Y30
Perhaps it’s due to having the wrong device selected: LightBurn is generating G-Code for a controller that’s not in the machine.
If so, following the steps listed in the doc linked by @parsec will help resolve the problem.
Are you connected to your laser by WIFI ?
Try using a USB cable instead (set up a new device in LightBurn and configure it to use a ‘Serial/USB’ connection;
I have noticed that it is more common to see errors 20 & 22 when connected wirelessly.
