Hi everyone. I’m looking for a diode laser to cut wing ribs and former out of balsa and up to 6mm ply. Going to mount it on my home made gantry. Using grbl on an arduino and lightburn.
Thoughts?
Peter
Thoughts?
Peter
Are you looking to buy a new laser? A 10w laser will struggle to cut 6mm ply anything. Without knowing what kind of wood that ply is, I know not if a 20w or 40w laser would be appropriate.
Are you looking to buy a laser module and bolt it on? Is your power supply and frame capable of supporting a higher power module?
Yes just looking for a module. The machine had a 100w Co2 laser but I killed it. Hoping around 20-40w.
The head on a CO2 laser is much lighter than a 20 or 40w module. That may cause flexing issues in the gantry.
You did not mention what controller you will be using. CO2 lasers typically use Ruida controllers. Diode lasers typically use a GRBL controller. CO2 are analog and diodes are digital.
Go slow, plan ahead, and you should be able to make it work.
The gantry is big. 50mm x 3mm rhs for the frame and the head is running on 2x 20mm bright rod and linear bearings. Table area is around 1200 x 600. Software is lightburn with an arduino uno and 3 x DM556 stepper drivers. 24v.
I have everything just need a new module.
I am a fitter and turner by trade and also built a cnc router running a Dremel.
Regards
Sounds like you don’t need my help. I am biased, but Sculpfun laser modules are notorius for having a long DOF (depth of focus). The 40w/20w module has the switch on the front, meaning no special wiring. I also read their 70w module has the dot size of a 20w module.
Of course, adapting the wiring might be required.
Hi @Prboz1
Balsa shouldn’t present much of a problem for a diode laser, but 6mm plywoods are another matter, particularly if it’s aircraft-grade birch ply. I’d be looking at a 20–40W optical-output diode (check the actual output, not the advertised power!) with decent air assist and extraction.
That said, if cutting is your main objective, I’d be inclined to go straight back to CO₂. It’s simply a much better tool for the job, particularly with thicker plywood. Faster, fewer passes, and generally cleaner results.
Given that your machine originally had a 100W CO₂ tube, I’d be interested to know what happened to it!! If the gantry and the rest of the machine are still in good condition, restoring the CO₂ system might be a better and cheaper investment than fitting a high-powered diode, with all the shenanigans of diode sellers, power supplies, wiring, focus, and air assistance.
A modest 50–60W CO₂ tube (shorter and a smaller PSU) would be more than capable of the sort of work you’re describing, so you wouldn’t necessarily need to go back to 100W either.
With my old laser tube the operator had a brain fade and forgot to turn the water on. For me to replace the 100w tube or get a 50-60w and a new laser driver it’s close to $1k Australia. I’m hoping to get a diode for less than half that. It’s only for me as a hobby so won’t be that heavily used.
Peter
