Wht does my sizes change on there own
Hi
I have managed to get the laser to go around the material without a problem.However when I try to burn an image and press start " cut out maybe out of bounds and the settings change Any help
There is a feature called Overscan that allows the engraver to run back and forth while keeping the engraving speed consistent. To do this it has to speed up and slow down when it’s not engraving, so the motion intentionally overshoots the edge of the image.
You can see this behavior in the preview window by selecting ‘Show traversal moves’.
This feature is exaggerated by excessive speed, which in some cases can add counterproductive time to a project.
Moving the project away from the left or right edge in the workspace often resolves this.
The following may be worth review.
Thanks John
I will give this a try,if I cant do it,I might call it a day with laser printing.I have spent over a week 8-10 hours a day and got absolutly no where
Cheers
Bernard
I assure you this is neither fair nor accurate.
You’re a lot closer to the finish line than you think you are.
Thanks John for your support.I have put a msg on local FB to see if anyone is using lightburn.I must be doing something wrong maybe watching to many videos of people doing laser printing.I just cant seem to get my head around it.I did 3d printing for years and thought this would be the same princple with settings etc
Cheers
