Why cant i all of a sudden connect my laser to lightburn. Worked well up until now. All it says is waiting for a connection. It works with a different program but not with lightburn which it did up untill now
Is the other program still running? Anything else change?
no the other program is shut down. and i restarted my computer a couple times and nothing works. nothing has changed as far as i know. but i havent used it in a couple weeks but that has never been an issue before
Did you choose a COM port?
it just says waiting for connection, and once right before i closed the program it said connected for 29 milliseconds
yes it gives me three to choose from and i tried all three none work
would it work to reinstall lightburn?
You can try it. That rarely solves anything, but if a file was corrupted that could help.
so what do u suggest i try then?
I’m at a loss. You said nothing changed, so there’s no reason the board would simply stop working in LightBurn but keep working elsewhere. Try re-installing. We also have a new version coming that includes a fix for some Arduino communication issues, and that might help too.
i just uninstalled and reinstalled and it still does the exact thing. when is the next version coming out? i really need to get this working!
Is there no way to run a debug or something that you could see what the problem is?
It still doesn’t work even after the new install you sent me… all I am getting is a short laser beam when the program starts or when I select it and then it says waiting for connection
Do this:
- Run LightBurn
- Go to Help > Enable debug logging (at the bottom of the help menu)
- Choose a COM port
- Count to 5
- do that for each of the 3 ports
- quit
You’ll find a file called LightBurnLog.txt in your Documents folder. Attach that here so I can have a look.
COM3 worked, connected, and got a response:
15:16:25.398 D: Name: "COM3"
15:16:25.398 D: Port open succeeded
15:16:25.461 D: EV: 1001 took 18 uS
15:16:25.461 D: "starting" busy: false state: 0
15:16:25.461 D: EV: 1001 took 4 uS
15:16:25.461 D: EV: 1018 took 6 uS
15:16:25.461 D: EV: 1015 took 505 uS
15:16:26.692 D: "Attempting to connect" busy: false state: 1
15:16:26.692 D: "Connecting..." busy: false state: 1
15:16:26.708 D: O: "G0\n"
15:16:26.833 D: I: "\r\nGrbl 1.1f ['$' for help]\r\n"
15:16:26.974 D: "Connecting..." busy: false state: 1
15:16:27.005 D: O: "G0\n"
15:16:27.005 D: I: "ok\r\n"
15:16:27.240 D: "Connecting..." busy: false state: 1
15:16:27.240 D: issuing buffer check
15:16:27.240 D: "Waiting for response..." busy: true state: 5
15:16:27.271 D: O: "$I\n"
15:16:27.271 D: I: "[VER:1.1f.20170131:]\r\n[OPT:V,15,"
15:16:27.286 D: I: "128]\r\nok\r\n"
If you use COM3, it doesn’t work?
Tried it now and it works. Thank you i appreciate that. after the update i actually didn’t check if i can move the laser, it didn’t pop up under devices so i assumed it didn’t connect properly again. Sorry for that! Works perfect now. Thanks for the quick response and support!
