why is it cutting outside first then inside should be the other way around.
Thanks
Rudy
cut.lbrn (28.3 KB)
Thanks
Rudy
cut.lbrn (28.3 KB)
Good question. I ran it and it cut all the insides first like I would expect.
Your shapes arenāt closed:
If the shapes arenāt closed there is no āinsideā - they have to be continuous loops. You can tell LightBurn to connect them for you by selecting everything and pressing Alt+J to auto-join everything.
Thanks for the Alt-Jeff shortcut. Oh wait. That was join wasnāt it?
Actually, it is both Jeff.
Thanks everyone that was it cuts like it should.
Rudy
Alt+Jason, actually.
That shortcut would have helped me the other day if I knew about it. Spent an hour joining things with the node editor lol.
I can share good news, the software comes with documentation. Hotkeys - LightBurn Software Documentation
At the bottom of that page is our recently updated āsingle pageā Hot Key Guide in easy to print PDF format.
Yea I read that for the node edit but didnāt think to look for anything else.
