Why only the bottom half of the design is engraved?
In my design it looks good in the program but preview only shows bottom half of the words?
ScreenHunter_165 Mar. 31 12.51
ScreenHunter_166 Mar. 31 12.51
Any idea why?
Do you have a kerf offset set?
I don’t know what that is? Where would I find that setting if I didn’t set it up?
Wrong image
Also maybe tabs turned on?
Here are my settings for that layer.
ScreenHunter_167 Mar. 31 13.42
The Tabs/Bridges being enabled is likely cutting off the portions of the layer that you’re saying are getting removed. Disable that.
That worked Thank you! I am glad I joined this forum!
