I have a problem with the shift of the shapes, in filling mode,on the same object you can see on the left it’s 3mm and on the right it’s 5mm.
My setting is 5mm outer shape shift, with 1.707 lb base settings.
It doesn’t seem coherent and this on two vectors.
I specify the rest of my route has no worries, all the lines are closed and without duplicates.
Thank you in advance!
