Wierd action in the corner
Hi All,
Everything was going fine as of 3 days ago, when i was installing the Camera,I was in had finished the camera alignment, I shut everything down as normal and the following day i was back outside and for some reason my laser seems ‘stuck’ at its home position.
Ive checked the rails/motors/etc and they are normal.
If i send it to frame a square in the middle,thats fine,tell it to fill or line it moves about 1 mm and thats it.
I then have to click stop and then home it and it will frame again ok.
If i change the settings to current position, It behaves as normal…
any ideas please will be appreciated as i feel very stupid at the moment!!!
Ta..
Hi,
You might be sending your laser outside its workarea. When this happens, you should see some errors in the Console Window
Please see if the info on this page helps clarify things:
