WiFi Borescope?
Would we be able to use a Klein Tools ET21 WiFi Borescope for the LightBurn 2.2 Print and Cut feature, or just a USB Borescope?
THANK YOU for that!
This also applies to most (many) Wifi endoscope cameras, unfortunately. It can easily be said that if a separate APP is required, then Wifi is built as an “Acesspoint” and cannot therefore function as a server/client and be added to your private Wifi / W-LAN.
I myself have been in the same position yesterday and find it annoying, because this type of camera can be bought for relatively little money and will make the installation somewhat easier. It is possible that you can hack the AP mode device and modify it, but I do not know.
I agree, it would’ve been nice for it to work, but I will just buy the one that Lightburn recommends.
I am not aware that LB has or recommends a specific heatmount camera.
I am experimenting with a very cheap inspection camera on USB, it works but my MacOS is not very fond of save/reserve/release port addresses, so there are some connection problems.
I don’t think they have endorsed a camera publicly, but several people that have contacted them privately have been told to use a specific camera. I’ve posted a link to one of them below for you.
I bought a very cheap USB Vuexar 2K Webcam, Model TWC25, from Amazon. Although 2K, it works like a charm.
I have also used my IPEVO Ziggi_HD Plus, 5 Megapixel, 2592x1944, with excellent results doing a Trace as well. This one is on a gooseneck base, so I use a calibration stick to set the height.
