WIFI connection
My LM 3 LE has been working fine, but now it won’t hook up to wifi even though it finished the setup process. LB 1.4.03 The unit is 6" away from the computer and it has been doing just fine for the last few months. I have rebooted and turned it off/on I have it connected by USB now but I’m lost as to why it won’t connect. I entered the wifi info all was acknowledged with (ok). I even used the Laser Explorer App and that connected and worked. So is this a LB question or please advise where to post this? Thanks
You done the wifi setup via commands ?
$i in console, post output here please?
CLUSTER:16]
Cluster size found
[WIFI MAC:58:CF:79:A6:FF:FE]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Your machine is on AP mode
In console type:
$74=mywifissid
ress enter
$75=mywifipassword
Press enter
$WRS
press enter
WAit for ip to change from 192.168.5.1 to something different
Mywifissid and mywifipassword are of course to be replaced by your own, case sensitive
Thank you once again sir, It seems that I had to make a new entry for a new laser and that reconnected using WIFI, I did try to edit the original and it look good but never found an open port. Either way its working now both WIFI and USB if needed.
Happy Holidays to you
ok
[MSG:79:Warning: WIFI STA`s setting has changed,reboot or $WRS to apply.]
$WRS
ok
[MSG:70:Info: WIFI AP STOPED]
[MSG:69:Info: WIFI AP READY]
[MSG:74:Info: WIFI STA ACTIVE]]
[MSG:77:Info: Get IP 192.168.1.153]
Waiting for connection…
Port failed to open - already in use?
Awesome! :slight_smile:
