is it possible to switch the wind output ON
for testing (to set pressure at the kompressor)
without starting a job?
thx
tom
thx
tom
See if this solution may work for you:
no problem
i thought may be there is a " Air Assist" test button at the sw
thx
tom
I often have the need to adjust the pressure to specific settings depending on the goal. To do this with my analog pressure gauge, I usually just draw a vector on a separate layer with air assist on and a power level of 0% and a ridiculously slow speed. I then select this and cut selected and adjust the analog regulator.
I’d like to replace the regulator with an Electro-Pneumatic model (electronically controlled / set pressure), but they’re expensive.
I’ll also add these suggestions. If you’re utilizing an air compressor:
Today, I had this bright idea and immediately thought back to this post to show you. Post regulator, I just put in a compression tee. One branch of the tee goes to the laser (as it had been), and the other branch just goes to a little cheap freebie harbor freight blow gun.
It’s such an easy / simple way to effectively adjust the regulator and dial it in to being the expected pressure when the solenoid opens on the job!
I believe you need to wire in a test button. Use 24V and and ground to open your solenoid.
This topic was automatically closed after 6 days. New replies are no longer allowed.
