Wizmaker 12 Problem
I am getting the following error with my LIghtBurn software.
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
My Wizmaker will move on the X Axis to the left, but will not move at all in any position on the Y axis when the HOME command is issued. Everything looks good on the cables.
  1. In the Device Settings window, turn off Auto-home on startup.
  2. In the Machine Settings window, turn off the $22 Homing Enable parameter.
  3. Turn off the machine, move the laser head to mid-workspace.
  4. Power up the machine.
    Using the Move window, does the machine move in the correst eirection when you Jog?
Does your machine have limit switches?
