Work area dimm's & Homing coordinate
Evening all.
If a work area of 600mm x 400mm is to be reduced…say by 5mm on both axis, will it also be necessary to adjust the Home coordinats to match where the new Back left corner would be?
Snapmaker ray
20w
integrated controller
I also have a situation where the module while moving on the X axis in either direction will Judder quite loudly…and then smooth out. It seems to be moving or attempting to move quickly when this happens and then it reduces speed a bit and moves very smoothly. It Homes ok (back left) but I have to input $X into the console alot to do anything
I only fired it up today and am getting the Info Overload experience, but I think it could be a speed setting…which from memory is at 600mm/m…(Max S 1000)
I discovered I have a snip tool on the laptop to capture screens & settings but the battery is low and I left the charger at the workshop, so some general insights might clue me in until I get back there and can screencapture.
I also have some ‘error 9’ and ‘G-code lockout’ on the pannel and will just have to work through those, while getting used to screens etc and if I draw a rectangle and hit Start…it moves along two sides (back Horizontal and Right Vertical) and then stops and when I tried to run a Speed/Power test…it sort of tried to do something…but then didnt.
Hope thats not all to vague!
