Work with .svg pictures
Hello everyone!
I have problem with work with .svg pictures. When I eliminate some shapes from picture the lightburn start to ignore some other shapes which are still parts of picture. Pleas advice me what kind of tools I would use for work with .svg pictures to be able to apart picture to pieces, delete some parts and set up picture back.
Thanks a lot.
L.
Can you share the .svg file? You should be able to attach it. It would also be useful to see screenshots illustrating the problem.
Like many standards, .svg has many flavours. Where did you generate the .svg?
When you say “picture” do you mean an embedded bitmap image like a photo OR are you using the term to describe your graphic?
Thanks for your ansver!
I am sorry, I can not share it because of copyrights.
I have svg from the author of the picture actually graphics. But now I have tried one more think and it looks like it work. If is nou I will write again.
I did not solve the problem.
I am not able to burn the grapfic not like a line but like fiil surface.
(how can I attached lightburn file to the message?)
(I am sorry for my english …)
For the Fill Mode to work, your shapes need to be closed.
You can change the View Style to “Filled” visualize this better.
Check out this video:
If you want to attach a .LBRN2 file, you can just drag and drop it into the reply box.
