downloaded a image png file to burn. first one was 317DPI and line interval at 0.080.
That one came out fine. Tried to tweak the next one with more speed and more power, but when I set line interval at 0.080 the DPI keeps defaulting to 12 not 317.
Any ideas ?
Jeff
Can you take a screenshot of what you’re seeing?
The interval and the dpi have a mathematical relationship, so they are computed when you change one or the other…
The interval is how many lines in a mm, so if the interval is 1, the dpi is 25.4. 1 line/mm 25.4mm to an inch. An interval of 0.10mm relates to 254 dpi.
Make sense?
You sure you didn’t accidentally change your units to imperial/fractional/sae?
.080" is about 12 lpi.
