I just got the Ortur laser max 2 and the lu 1-4 laser. I watched a few videos because the lightburn software was not finding my rig, so I manually entered it. I used 400x430mm for the working area. I am getting a jog error as it thinks the area is too big which after reading these forums it appears someone has already used this fricking laser and installed a small unit firmware on it. I know I can’t make the firmware update via my MAC but is there a way to run some code in the console to make these changes? Your help is greatly appreciated.
OK so I changed 130 and 131 to 410 and 390 and that seemed to be a workaround when using the origin tool. I was even able to get this to print, but the print was backwards.
If your laser output is mirrored horizontally or vertically, move the dot to the opposite corner, horizontally or vertically, depending on the direction that the output is mirrored, and that will correct it.
I am actually burning an image as we speak, dont get excited I had to mirror the image on the pallet to make it burn correctly. As soon as it is done I am going to change the device origin to the top right corner adn tell you what happens
So after making those changes and changing the g130 and g131 to reflect those travel dimensions it still upon boot up wants to travel down, then right and crashes.
